1976 Olds 442
1976 Olds 442
Good afternoon Gents,
I have an opportunity to purchase a 1976 442 in very good shape. It is 260, 5 speed equipped. I have a lot of experience with pre-72 442's but zero experience with later models.
I have an Olds 350 engine that I can rebuild. I would want to convert this car to a 350, Muncie equipped M-20 car. This car currently is set up for manual trans (5 speed factory). Can I use the current
manual pedals, linkage and bell housing as equipped on the 350 along with the Muncie? Can the current trans cross member be reused as well as the drive shaft? I also will change out the
rear end with either a Moser and or Currie new unit. Any thoughts on the technical side of this upgrade with regards to reusing the manual transmission set up as equipped?
Thanks as always for your time and review.
Frank
Frank
Thank you all gentlemen for your feedback. I assumed that was the case but as I stated previously I have no experience with the later 1970's cutlass and re-usability of existing mounting, driveshaft etc.
Frank
Frank
