65 442 -New Engine-Trans Question
I've been an owner of modern muscle cars ( Roush Mustang, Challenger SRT 392), and have had a bunch of other muscle cars when i was a kid. Decided to buy a 1965 F85 442 from a dealer in Florida. I used a local inspector and thought I was good to go. Turns out the inspector snd dealer do a lot of work together. Anyway, while the the car is a true vin-confirmed 442, it is beat to death and has a replacement but also beat to death 350 Rocket in the engine bay, and the 2-speed Jet-Away auto trans is pretty bad as well.
I am having a new Olds 455 built rated at 425HP. My first question ( many will follow) is, what trans can I mate with the 455? Best case scenario would be to drop in a 4-speed manual, but I think that may be too costly. Option two would be to drop in a 3, 4, or even 5 speed trans. Any thoughts on an auto trans that will mate up with the 455?
Frontierman
Any input is appreciated.
Frontierman
While your having the engine built, if the crankshaft isn't drilled for a manual transmission input shaft this would be the time to have it done. Most 455 crankshafts don't have this but a competent shop can cut it before assembling the engine. Here's a link to an old thread that shows the factory spec's to cut for a pilot bearing or bushing.
https://classicoldsmobile.com/forums...ns-crank-9757/
If a 4-speed manual is what you really want, you should do it. You're in for a pretty big bill anyway, so you might as well go all the way and end up with something you'll be happy with. No fitment issues with Muncie M-20/21 as they were OEM supplied. All you need to do is get a shifter, pedal set-up, clutch and linkage as well as making sure the crank is drilled for it as noted above.
That's impossible, not a stand alone model. No way to verify a 1965-1967 442 with its VIN number.
THM400 is the ideal match. It takes away all the guess work.
^^^THIS. There is nothing in the VIN that will allow you to "prove" the car is a real 442. The cowl tag WILL have a code that will prove it, assuming this is not a Fremont-built car.
