1973 442 4spd interchange
Old Jan 3, 2017 | 07:28 AM
77olds's Avatar
I have a 77 cutlass and looking at a 1973 442 455 4 speed parts car runs drives body is gone and interior shot wondering if everything from 4 speed car will interchange into my 77 im thinking it will just what to check. Thanks, Derek
Old Jan 3, 2017 | 07:36 AM
Yes, assuming you use the engine that has the crank drilled for the pilot bearing. And the 73 will have a double hump crossmember vs. the single hump on a 77.
Old Jan 3, 2017 | 08:02 AM
vette442's Avatar
Hi Derek -
I'd love to get pics and info of the parts car if possible for the V Code registry site. I'm maintaining '73 info in addition to 1972 cars since I'm not sure that Bob Cline is doing the '73 V Code registry anymore. Thanks.
Terry
Old Jan 3, 2017 | 03:34 PM
macrover's Avatar
Derek - As Joe mentioned, yes the parts will or "could" interchange, depending on what you're changing.
What model/body style is your '77? Is it an automatic or manual?
Terry
, is that registry strictly for V-codes?
Old Jan 3, 2017 | 04:11 PM
68442's Avatar
Derek
I'm interested in the whole car(73 442) if this is available.
Would hate to see this parted out.
Sent a PM
Old Jan 3, 2017 | 06:47 PM
77olds's Avatar
My 77 is a cutlass supreme brougham I was planning on swapping the engine and trans and all the 4 speed parts pedals linkage z bar ect into my car and leave my 40/60 bench. I figured all the parts would interchange with little problems just wanted to double check.
Thanks, Derek
rod1589
Oct 2, 2013 11:51 PM
nukesec1
Cars Wanted
Jul 21, 2010 08:38 PM
1arunem
Nov 4, 2009 10:24 AM
1arunem
Sep 16, 2009 08:18 PM
montvaleplace
Apr 15, 2009 03:06 PM
