1970 Rocket 350 - Which 4 speeds were used??
Old Jan 13, 2010 | 12:02 AM
Aceshigh's Avatar
I'm looking to find out what 4 speed options there were
attached to the 1970 Rocket 350. I'm going to be on the
lookout for a factory bellhousing in good condition ASAP.
If anyone has any ideas, please post up the info.
Thanks.
Old Jan 13, 2010 | 02:30 AM
Bluevista's Avatar
Registered
The M20 or M21.
Old Jan 13, 2010 | 05:22 AM
2blu442's Avatar
And any Buick, Olds, Pontiac manual transmission bellhousing from the mid-1960's into 1970's will fit, if your not focused on the exact casting number matching. I've picked up a couple Poncho bellhousings off Craigslist. I think you can find a couple on ebay at any given time. The one wild card I've encountered is the late 1970's into early 1980's Omega used a different clutch fork setup. They had one that pulled with a cable. So look to see it has the fork setup. John
Old Jan 13, 2010 | 04:40 PM
Aceshigh's Avatar
Thanks for the info gents.
I was asking to determine if I would use an adaptor plate for the Old bellhousings or go with the Mcleod Universal Bellhousing that's SFI approved.
Putting a LS1 T56 6 speed in mine from a 90's Fbody .
http://www.summitracing.com/parts/MCL-8710-10/
dsa2207
Apr 2, 2014 03:41 AM
455Olds
Feb 10, 2014 12:04 PM
Johnd
Dec 18, 2013 09:47 AM
Aron Nance
Jul 6, 2010 11:34 AM
