1969 Cutlass Backdrive linkage Question?
I have a 1969 cutlass with a Turbo 350 trans/ floor shift console. The previous owner removed all Backdrive linkage components from column to trans. My question is what year Backdrive components will interchange with my application? I have been researching this issue, but I don't have a 69 assembly manual to verify part numbers.
I "think" but not sure that '69 is a 1 year only design?? I know '70-'72 are the same. If I'm right the long rod from the steering column to the frame bracket is different?? I think I have some if you find out for sure.
Scott- Thanks for the reply, I will get a hold of you when I know for sure. The part number I show for the long rod from steering column to the frame bracket in 1970 is 1382860. Does anyone know what the correct part number is for 1969?
