1969 Cutlass Backdrive linkage Question?
Old Mar 21, 2016 | 02:22 PM
sixty9olds's Avatar
I have a 1969 cutlass with a Turbo 350 trans/ floor shift console. The previous owner removed all Backdrive linkage components from column to trans. My question is what year Backdrive components will interchange with my application? I have been researching this issue, but I don't have a 69 assembly manual to verify part numbers.
Old Mar 21, 2016 | 05:42 PM
oldspackrat's Avatar
I "think" but not sure that '69 is a 1 year only design?? I know '70-'72 are the same. If I'm right the long rod from the steering column to the frame bracket is different?? I think I have some if you find out for sure.
Old Mar 21, 2016 | 06:27 PM
sixty9olds's Avatar
Scott- Thanks for the reply, I will get a hold of you when I know for sure. The part number I show for the long rod from steering column to the frame bracket in 1970 is 1382860. Does anyone know what the correct part number is for 1969?
Old Mar 23, 2016 | 05:17 AM
sixty9olds's Avatar
Does anyone know the correct part number for a 1969 Cutlass Turbo 350 backdrive linkage rod from column to frame rail?
postsedan
Jun 25, 2015 07:21 PM
69442murph
May 27, 2015 04:12 AM
69442murph
Jan 9, 2015 06:29 PM
tru-blue 442
Jan 26, 2014 05:04 PM
spate51
Apr 17, 2012 04:42 AM
