1967 Oldsmobile 330 transmission recomendations.
Old Mar 18, 2026 | 06:07 PM
Roald.B.Lundt's Avatar
I have 1967 330 oldmobile motor, and was wanting to know if anyone has recomendations for manual transmission to put with it. Or am i better off finding a th350 for it?
Old Mar 18, 2026 | 08:19 PM
66SportCoupe's Avatar
Least expensive and I think the best would be a TH350. Otherwise people might tell you 200R4.
Old Mar 19, 2026 | 04:53 AM
JohnnyBs68S's Avatar
Check the crankshaft to see if it was machined to accept a pilot bearing for a MT input shaft. If not, the crank will need to be machined accordingly. There are threads on here about what is needed to do this.
If the crank will accept a pilot bearing, any MT used w/ the 330-455 Olds motors will bolt up to a factory bellhousing. Will need to add clutch pedal and lever parts (chassis holes should already be present), side of engine block should have hole tapped for ball pivot).
Old Mar 19, 2026 | 02:36 PM
Nearly all Olds motors that came from the factory in front of an automatic trans did NOT have the crank machined for the pilot bushing. If you want a manual trans, your options are to use an aftermarket conversion bushing that fits in the torque converter nose recess in the crank (which requires you to cut about 3/4" off the nose of the transmission input shaft) or to pull the crank and have a machine shop properly machine the crank for the pilot bushing.
Old Mar 19, 2026 | 02:48 PM
The T350 would be the least expensive and easiest swap for your car. Frankly, I liked the Jetaway with switch pitch torque convertor.
Dabittner
Sep 30, 2022 11:21 PM
babailey
Apr 19, 2022 07:18 AM
thibidaux
Oct 9, 2019 07:41 AM
jensenracing77
Oct 24, 2012 04:04 PM
leep
Mar 25, 2010 07:48 PM
