1964 Oldsmobile Transmission Problems
Old Nov 19, 2006 | 05:11 PM
1964OldsmobileF-85V84Door's Avatar
Exclamation 1964 Oldsmobile Transmission Problems
Hi just pulled my 1964 Olds F-85 4 door out of the weeds after 15 years and my uncle was pulling me with his dump truck and just when i thought he was done pulling i put it in Park because it has no brakes then he pulled me a little further with the trans in Park then after we stopped i could not get her out of Park it was like jammed so it started raining so we pulled her out onto the road then with it still in Park skidding no we lifted up the hood and turns out the trans was rolling in the engine compartment no do i have to get this rebuild now because i screwed something up or is it just fine.thanks
NOTE: this trans is a 2-speed automatic dunno if olds called them powerglides but i put that in there.
Old Sep 24, 2008 | 12:01 PM
Kaline's Avatar
You have an interesting issue here. I would start with checking your transmission linkage...am sure it is jammed. From there, I would get a copy of the 1964 Oldsmobile service manual (Fusick sells them) and start diagnosing. Best of luck.
Old Sep 24, 2008 | 12:07 PM
88 coupe's Avatar
Junior Member
Check the post date.
Norm
Old Sep 24, 2008 | 12:08 PM
gearheads78's Avatar
car guy
Sounds like you need to get the trasmission back in to close to the position it should be. If the transmission is moving around you are binding up the linkage.
-Richard
Old Sep 24, 2008 | 12:09 PM
car guy
Norm
LOL someone was digging
-Richard
chasman414
Jun 25, 2020 07:05 AM
thoogylives
Jun 16, 2010 06:12 PM
bwichman
May 10, 2010 03:01 PM
toyktdlgh
15
May 14, 2008 06:52 AM
155thINF
Sep 20, 2006 10:15 PM
