1963 F85 shifting
Old Jan 1, 2012 | 07:34 PM
senginc's Avatar
1963 F85 shifting
Like most articles I have read I also have sloppy 1963 F85 shifting from 1-2.
If I start in S the 1-2 shift is quite good in Hydramatic style. I can then manually shift from S to D smoothly (a little sluggish into D but acceptable).
However, if I start in D when it shifts from 1, the engine revs up, then it tries to bang into 2 or D then back out back in etc.
Can this be improved by linkage adjustment?
I also have damper plate spring rattle at very slow idle ~500 rpm. Set idle speed up to ~ 850 rpm and no rattle.
I guess as long as I shift manually the transmission shouldn't get damaged any worse.
I had a Hydramatic old timer tell me to try K&W Trans X. Has anyone tried this additive?
Old Jun 20, 2012 | 07:35 PM
russell-t's Avatar
I also have a 63 f-85 and have figured mine out. Your problem seems
to be that your TV rod is too short. Thats the adjustable rod that's connect-
ed to the carb at one end and the trans link at the other. After trying for
several attempts I finally have a smooth 1-2 shift. The length of the TV
rod is just a little over 5 1/16 inches. This length is variable beween cars,
These automatics are sensitive to this adjustment,and it doesn't take
much( 1/8 inch or less)to get the right shift point.
Old Jun 21, 2012 | 08:21 AM
Correct. The special Burroughs Tool gauges called out in the service manual are not really available, so I've resorted to trial and error. Just make small changes and test drive until you get acceptable shifts.
trackz man
Aug 29, 2016 04:32 PM
maskinen
Aug 17, 2008 11:29 AM
GOLD72OLDS
Oct 31, 2007 05:34 PM
nohn
Jul 22, 2007 10:57 AM
<jdhideaway@aol.com>
Brakes/Hydraulic Systems
Mar 31, 2005 08:15 PM
