1960 Oldsmobile transmission identification
Old Aug 26, 2022 | 11:34 PM
Hippy Dave's Avatar
Hi All,
I am a new member and need to identify what transmission is behind my 371 cubic inch 1960 Oldsmobile.
My previous post has been answered, thank-you to all who assisted in the identification of the engine, however I can not definitively name the transmission type so I can continue my build with the right parts.
The transmission has the following numbers cast into the top of the pan just new the selector: 4C 8618721 AL 6N29
It has a 32 spline output shaft with a overall diameter of 1.365"
Here are the images of the casting numbers and the overall transmission.
Old Aug 27, 2022 | 05:47 AM
The only automatic offered by Olds in the 1960 model year was the Jetaway Hydramatic (also called the 315). It should have 14 bolts on a relatively square trans pan.
Old Aug 27, 2022 | 04:09 PM
Hippy Dave's Avatar
Thanks Joe.... All I now need to locate, is a 32 spline front slip yoke to suit...would you have anything? Regards Dave
Old Aug 27, 2022 | 04:34 PM
2blu442's Avatar
Dave, if your still looking for a yoke I think I can help. Did the other guy not have the correct one?
John
Eddie Hansen
Site Suggestions
44
Nov 30, 2022 07:51 AM
Dan Miller
Oct 3, 2021 07:24 AM
F-85 4-4-2
Mar 3, 2021 07:49 AM
66ninetyeightls
Aug 27, 2009 06:42 AM
Oldsmobile1958.com
May 31, 2008 11:37 AM
