1955 Olds Hydramatic
Old April 5th, 2016, 10:00 PM
49mercpapo's Avatar
Will a transmission from a 1955 Oldsmobile fit on a 1956 Oldsmobile 324?
49mercpapo is offline
Old November 1st, 2016, 11:06 PM
rocketbob54's Avatar
A 1956 88 came with the Dual Range (Slant Pan) HydraMatic transmission (like the 1955 trans) and the '56 S-88 and 98 had the new JetAway HydraMatic. To answer your question, it depends on the crankshaft. The Dual Range transmission requires the crank to be drilled with a pilot bushig installed and the JetAway does not. Check the flywheel end of the crank and you will know. The flywneels are also different.
rocketbob54 is offline
d2_willys
February 4th, 2015 07:24 PM
Olds Scott
February 27th, 2013 09:19 AM
Mad Scallywag
18
April 20th, 2012 09:06 PM
American Lead
24
March 17th, 2009 07:48 AM
Jet Doc
November 2nd, 2008 11:55 AM
Quick Reply: 1955 Olds Hydramatic
