1947 hydra-matic torus to flywheel gasket
Old June 2nd, 2018, 07:58 AM
77olds's Avatar
I’ve started the process of swapping the engine in my 47 oldsmobile with another 238 olds flat 6. And found out the hydra Matic is a pain. I need a gasket for my torus to flywheel it has 30 bolts with 2 dowl pins. I’ve looked online and some company’s gaskets start in 1948 would that work. Any info would help.
Thanks, Derek
77olds is offline
Old June 2nd, 2018, 09:40 AM
Thanks, Derek
Have you tried Fatsco?
joe_padavano is offline
Old June 2nd, 2018, 09:55 AM
77olds's Avatar
not yet I’m will call them Monday. Thank you
77olds is offline
Old June 2nd, 2018, 11:02 AM
Phantom Phixer
Charlie Jones's Avatar
No , my 1950 Olds parts book lists 42 thru 47 gasket as #8602257 .
And 48 thru 50 as #8611284 .
If Fatsco can't supply, you might try googling David Edwards in Needham , MA .
He also has a good supply of early Hydra-Matic parts .
Charlie Jones is offline
Old June 2nd, 2018, 02:25 PM
Tedd Thompson's Avatar
Or if all else fails make one out of gasket material. It would take a little time but should be doable.
I could be wrong but isn't that gasket made of a very thin onion skin material?.... Tedd
Tedd Thompson is offline
Old June 4th, 2018, 07:13 AM
77olds's Avatar
Thank you I will try those options.
77olds is offline
spencer83
January 15th, 2019 08:06 AM
T money
July 27th, 2018 12:24 PM
Dave T
March 29th, 2018 11:18 AM
dele
January 19th, 2017 01:14 AM
spyke
March 28th, 2013 08:13 PM
Quick Reply: 1947 hydra-matic torus to flywheel gasket
