66?Toro runs shaky when warmed up
Old Jan 31, 2022 | 02:01 PM
sgolds's Avatar
Mine came with a rebuilt Rock Auto q jet, it starts to run shaky and sometimes bogs from a start when it's warmed up. Kind of a rhythmic shaking, doesn't stall but seems almost like a misfire. Any idea what might cause this?
Old Jan 31, 2022 | 02:04 PM
66SportCoupe's Avatar
With just replacing the carb i would be checking for a vacuum leak of some sort.
Old Jan 31, 2022 | 03:21 PM
Shaking means misfiring.
Old Jan 31, 2022 | 03:23 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Put a vacuum gage on it and see how much vacuum it is pulling. It should be at least 15 inches. I am betting vacuum leak.
Old Jan 31, 2022 | 03:42 PM
And, while you have the vacuum gauge hooked up adjust each of your A/F mixture screws (independently) to the highest vacuum you can achieve.
Old Jan 31, 2022 | 05:19 PM
sgolds's Avatar
Old Jan 31, 2022 | 05:21 PM
sgolds's Avatar
Yeah I'll have to work on checking the vacuum with my vac gauge when the temp here gets milder and the roads clear of salt etc.
69442C
Apr 29, 2021 03:35 PM
my72olds
Dec 19, 2014 10:57 PM
jaymann
Oct 19, 2011 10:41 PM
rpc45040
Oct 17, 2010 08:33 PM
novice57
Sep 8, 2007 07:25 AM
