Whistling sound from brake pedal
When the car is running I get a whistling sound from the brake pedal area when pressing the brake, it only whistles when the pedal is moving. I don’t think it does it when in Park, only starts when in D or R.
I don’t think there are any vac lines connected to the brake pedal in a 66 Toro? It’s def under the dash near your right feet. Kind of intermittent, sometimes does it and sometimes not.
Does your car have cruise control? Does it work?
66 cruise was still electric motor-driven with no vacuum connections unless it's aftermarket. My thought is a small vacuum leak on the power brake booster. Do you notice a rougher idle when this happens?
It's the part called the "poppet valve" in this diagram.
![](https://cimg4.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/1600x1242/power_brake_automobile_vacuum_poppet_valve_booster_c39f2e4fc7b58756aa93a8cf463bd584102d3eb6.jpg)
The way I found my booster was going bad was the motor smoothed out a lot when I disconnected the booster and plugged its vacuum port on the engine.
Once the booster line wasn’t a vacuum leak to the engine, it was pretty clearly time for a new booster. I think I might have had mine rebuilt, can’t recall.
They can eventually go bad, especially after 55 years. Surprising how well the vacuum components hold up in my ‘66 cars.
They’re so good, they make us question whether they’re going bad.
Cheers
cf
Cheers
cf
See my response in your other thread. This is a one-year-only application for a car over a half century old with extremely limited numbers still on the road. NAPA says none are in stock for shipment, and "call store for availability", which is their code for "lotsa luck". Most sources will rebuild yours when you send it in - they have no cores to rebuild otherwise. Sure, there's a small chance that you'll stumble onto a parts store that has had one on the shelf for the last 25 years. I hope your luck is better than mine for that. These are cars with limited popularity, small numbers surviving, and there's no business case for a company to stock one today when it might sit there for 5-10 years. Fusick doesn't have any, and they are the most likely source.
