Toro Trans Leak
Old Sep 9, 2015 | 12:50 PM
z11375ss's Avatar
Senior Moment Member
Toro Trans Leak
Ok, I have an issue where the previous owner drilled a hole or three trying to get the seal out of the trans at the input shaft. Replaced the seal and now it leaks just as bad as it did. My guy is pushing the converter in a bit and washering it to see if it clears it up. Anyone else have a problem/remedy with this type of leak on a Toro or any other car for that matter?
Old Oct 18, 2015 | 06:23 PM
z11375ss's Avatar
So posted this over a month ago. Found the leak. It's behind the front pump cover? The whole assembly had to be taken out the back side of the trans case. There's an o ring that is leaking. The motor has been out for a long time now. Maybe by next year it will be done. Probably not though. My hopes are not high. As soon as I get it away from the guy who has it now it will stay away from there. He needs to fix it though. It's paid for. Ouch.
tcarroll
Apr 25, 2014 03:16 PM
dephconn24
Jun 17, 2013 04:04 PM
Railguy
Apr 20, 2011 09:33 AM
fitter bill
Jun 28, 2010 08:40 PM
yeahbuddy
May 7, 2010 08:54 AM
