newbie with trans leak
Old Jun 27, 2010 | 01:51 PM
fitter bill's Avatar
hello all first thread ,i got 72 cutlass s 350 trans & motor and has a leak on passsenger side of trans from some sort of pressure switch by fill tube & kickdown cable that appears to be wet can anyone tell me what this switch is for ? thanks bill
Old Jun 27, 2010 | 02:10 PM
OLD SKL 69's Avatar
GM Enthusiast
Welcome Bill to the forum. Sounds like it is the transmission kickdown solenoid that's leaking. I am not sure if any auto parts house carries just the gasket. If they do not have just the gasket, you could try a transmission shop and tell them what you need. Otherwise, you would have to order a new switch and I am pretty sure that comes with a new gasket. Hope that helps.
Old Jun 27, 2010 | 03:00 PM
thanks for the responce i checked at auto parts store they had a picture and it wasn't a solenoid . this thing has one wire on it .had a 70 cutlass back in the day and i think i replaced it also and i could swear it was for the back up lights but with this wire disconected the lights still work i dont know bill
Old Jun 27, 2010 | 08:36 PM
Bluevista's Avatar
Registered
Wouldn't that be the transmission pressure switch for the Transmission Controlled Spark (TCS) system?
Check this out.
https://classicoldsmobile.com/forums...cs-switch.html
Old Jun 28, 2010 | 05:26 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO. Hope you get the leak fixed.
Old Jun 28, 2010 | 02:19 PM
after doing more research last night Bluevista i believe you are correct sir.and since i no longer have tcs since changing to edelbrock manifold & carb i guess i could remove switch & plug the hole thank guys BILL
Old Jun 28, 2010 | 02:26 PM
Hey Blue,
He called you sir. Sandy uses another description
Old Jun 28, 2010 | 08:40 PM
cutlassgal's Avatar
Cutlass Lover
I've called him sir too.... just not in the same context as Bill, lol!!!!
Macadoo
May 31, 2014 02:30 PM
tcarroll
Apr 25, 2014 03:16 PM
dephconn24
Jun 17, 2013 04:04 PM
Railguy
Apr 20, 2011 09:33 AM
yeahbuddy
May 7, 2010 08:54 AM
