Special request, please help toronado 69
Old Nov 30, 2015 | 09:27 AM
Amistydj's Avatar
Hi will anybody with a 1st gen toronado preferably 68-70 snap a picture of their underside of the steering colum where the fuse block and wired are for me?
My currently has some unplugged wires and I need to know where they plug to.
Any help will be appreciated
Old Dec 2, 2015 | 06:48 AM
bluecab's Avatar
Mostly Gristle
Is there something that is not working?
Is the column tilt/tele or standard?
What are the options on the car?
Old Dec 2, 2015 | 07:14 AM
Amistydj's Avatar
Currently everything looks fine, the stock radio is not there so the power antenna is not engaging at the moment
Cigar lighter has been disconnected, cant find a wire that goes there
Previous owner relocated the horn underneath the dash colum( stupid move) but they do work
I have the base version not deluxe ao no door mounted lights, just rear interior lights and under dash. All lights do work.
I just dont know what those loose harness are for
I have the tilt/tele
cruise control
AC and heat
I havent tested the cruise control as I havent really driven the car past 20mph yet, just couple laps around the neighborhood as im still working on the ignition.
Old Dec 2, 2015 | 12:42 PM
bluecab's Avatar
Mostly Gristle
I can't speak to your particular situation as I have a '66 that is probably quite different.
What I can say is that in my experience it seems many auto makers provide a single harness regardless of the actual equipment installed on the car. This probably costs less than making a different harness for each possible configuration of the vehicle.
Who knows, with GM they may have had a single harness for the Eldo, Toro and Riv that year...
So, if everything works I would not worry about it.
Old Dec 2, 2015 | 01:00 PM
Amistydj's Avatar
Yeah good point, I was just curious
krauser65
Apr 29, 2014 08:26 AM
TomType1
Apr 1, 2014 07:48 PM
acheslow
Nov 6, 2012 09:47 AM
rket56
Jul 1, 2012 04:54 PM
bcg88
Jan 28, 2009 01:57 PM
