Removing inside window trim
Old Jan 6, 2021 | 04:53 PM
sgolds's Avatar
Trying to remove the painted metal trim that goes around the windows inside, 66 Toronado , any advice on just how they come out? I removed the screws but it's obviously held in some other way. Are there any hidden screws I'm missing?
Old Jan 15, 2021 | 01:45 PM
sgolds's Avatar
Anyone? 😳
Old Jan 16, 2021 | 05:47 AM
Bill's Auto Works's Avatar
The one that goes across the top of the windshield usually has had some of the windshield seal ooze down onto it holding it in place after the screws have been removed.
The piece that goes down to the "C" pillar has just the one screw at the very back & has spring clips that keep tension on the pinch weld. After removing the screw at the very back, pull straight down starting at the front being careful not to tear your headliner if you are not replacing it.
God bless
Bill
https://www.jalopyjournal.com/forum/...closed.614419/
Old Jan 17, 2021 | 08:43 AM
sgolds's Avatar
What about the A pillar molding? How does that come off?
Old Jan 17, 2021 | 09:31 AM
Nothing but the 4 Phillips screws! Some careful prying may be necessary.
God Bless
Bill
Old Jan 19, 2021 | 12:11 PM
sgolds's Avatar
I tried removing the screws on the A pillar mldg but it would not come out, is there a clip on that one as well?
Old Jan 19, 2021 | 12:33 PM
No clips on either "A" pillar, just the 4 screws. Again, there may be a possibility some of the windshield sealer has oozed down onto the edge of them. If I get a chance I will take a picture of the backside of one so you can see how it is made.
Old Jan 19, 2021 | 12:54 PM
sgolds's Avatar
Thanks that would be great. Bad design, the inside corner gouges/scratches the paint off the metal dash whenever the molding moves a bit 😡
Old Jan 19, 2021 | 01:26 PM
Ok Sir,
Here is the best picture I could do. I put mine back on just to see how I took it off...That is the problem with having done this stuff 40+ years, I don't really pay attention how I do things to tell someone else, I just do it.
I would lift it up from the dash about 1/4 inch with something like a brake adjusting tool (or a spoon for that matter) then pry it off from the outer side first. You may also want to run a utility knife from top to bottom where it is closest to the window to cut lose any window seal stuck to it. I noticed mine did have a little on it.
Hope this helps, I am better at doing than telling!
God Bless
Bill
Old Jan 21, 2021 | 01:53 PM
sgolds's Avatar
I will give it a try thanks
Old Mar 13, 2021 | 06:29 PM
66toro_mn's Avatar
I just had to remove these pillar trims myself for the first time. After the 4 screws you just pry on it. I had a set of plastic interior tools that I could pry and pull on it. The trick for me was pulling evenly (top and bottom) towards me. Whenever I would pry just the bottom it would bend the top back into the windshield. After the screws they are just pressure fit or snap fit.
FStanley
Body work
Mar 2, 2017 11:20 AM
denf221
Body work
Feb 23, 2017 09:44 AM
Danielle's 71
Body work
Apr 21, 2009 02:42 AM
jensenracing77
Feb 23, 2009 04:19 PM
cutthroat
May 14, 2007 02:39 AM
