Headlamps Will Not Open
Old Sep 22, 2008 | 11:00 AM
elcaminodave's Avatar
I have a 1966 Toronado and the headlight doors will not open. I have a vacuum line diagram and have traced all of the lines and they seem to be fine (no splits). I have vacuum to one of the 3 hoses that operate the doors(yellow striped one that goes into the reservoir), but the other 2 do not seem to have vacuum. Are all three hoses supposed to have vacuum? Also, is there a simple way to check the headlight motor to make sure it is operational?
Old Sep 22, 2008 | 09:13 PM
2blu442's Avatar
1966 headlights
If you take a vacuum gun and start at the canister and work your way back. See where it stops opening, then look for a problem between those last two locations.
bwichman
Dec 31, 2012 04:32 PM
70CCV
Jun 30, 2012 03:50 PM
skryla
Nov 17, 2011 12:12 PM
pcard
Jul 13, 2011 11:55 PM
ckpksp
Ninety-Eight
Apr 26, 2011 09:53 AM
