FwD caddy Toronado Quast.
Old Jun 4, 2024 | 08:56 AM
STLCRZY's Avatar
Not sure but it seems like the cadillac 500 fwd trans nearly the same as the fwd toronado?
maybe someone can help.
Axleshaft
I must disconnect the trans from the engine But not sure if i have to open the diff cover to remove the shaft.?
I have unbolt all the bolts which hold the differential to the trans but no space unbolt the last fuxxx bold which hold the diffential to the trans.
Diffcover
Hope really some can help.
Old Jun 4, 2024 | 04:27 PM
Loaded68W34's Avatar
With a short wrench, or possibly a crow's-foot wrench on a ratchet, you should be able to get to that last fastener. If not, the passenger side shaft just pulls out of the differential once you remove the passenger side axle mount attached to the motor. You may have to tap it with a hammer to get it to release, but mine slid right out. Once the axle is out of the way, unbolt the torque converter and seperate the engne from the trans. Then you will be able to access the last bolt/ nut holding the differential to the trans.
Old Jun 4, 2024 | 10:36 PM
STLCRZY's Avatar
BIG THanks ....
Jun 6, 2024 02:11 PM
dc2x4drvr
Apr 8, 2024 06:48 PM
REO442
Mar 22, 2022 08:42 AM
HighwayStar 442
Sep 8, 2021 04:33 AM
Hal
Mar 13, 2013 09:24 PM
