😵‍💫 Front wheel cylinders...
Old Nov 25, 2023 | 01:58 PM
mike 66 toro's Avatar
Ummmm. Dumb question. How do I remove the front wheel cylinders? I removed everything but the hub.
Old Nov 25, 2023 | 02:24 PM
They bolt on from the rear side of the backing plate. Remove the brake line and the bolts. Remove the top springs and spread the brake shoes a bit.
Old Nov 25, 2023 | 02:43 PM
Was hoping to sneak it out with line still attached on back of it.
Old Nov 25, 2023 | 03:05 PM
Some idiot tightened every brake fitting on this car to 375 ugga duggas. I'll saw off the line and put a long socket on it I guess.
Old Nov 25, 2023 | 03:23 PM
2blu442's Avatar
Have you tried vice grips yet? You'd only booger two sides of the fitting and may be able to reuse it.
Old Nov 25, 2023 | 04:17 PM
Success. After dremeling off the old line, a deep socket worked almost ridiculously easily, as if to mock the 45 mins I'd spent trying to do this nondestructively. (edit: yep I tried vice grips and flare wrench) I have parts for the other side too, but it's not locking up like this side was.
Do I need to pre-adjust the toothed thing? I put it back as it was, and didn't change the shoes. Will this take care of itself? I've limited experience with drums.
Old Nov 25, 2023 | 04:19 PM
torotoyguy's Avatar
How about flare nut wrench with 5 sides of hex nut secured at same time, plus liberal use of penetrating oil
Old Nov 25, 2023 | 04:43 PM
If you’re not changing anything but the wheel cylinder you still may need to readjust the brakes when done. Note, if the shoes got saturated with brake fluid, that would cause them to lock up and they would need to be replaced. No amount of cleaning will cure it.
Old Nov 25, 2023 | 05:19 PM
ourkid2000's Avatar
I'm just a bit confused, which part of this was dremeled off?
Old Nov 25, 2023 | 05:24 PM
Old Nov 25, 2023 | 05:33 PM
ourkid2000's Avatar
Oh ok, thx. So that's the part that screws into the back of the wheel cylinder correct? Did you have any trouble finding a replacement hose?
Old Nov 25, 2023 | 06:17 PM
Yes it is.
Rockauto has the hoses (I got Dorman) and wheel cylinders (I got ACDelco). Everything looks good. I only tried the parts for right side so far.
Just asking again in case it was missed, I know my posts have twists and turns:
Do I need to pre-adjust the toothed thing? I put it back as it was, and didn't change the shoes. Will this take care of itself? I didn't put the wheel back on yet.
I think I shouldn't have said "lock up". I meant that the brake would apply but not release for about an hour, which is why I got the hoses but the wheel cylinders are cheap so I got them too.
Old Nov 25, 2023 | 06:20 PM
rocketraider's Avatar
Oldsdruid
One side, maybe both, the upper ball joint has to come loose to tilt the spindle out for access to remove the front wheel cylinders and hoses. Like a lot of things Toronado brake hydraulics can be a PITA.
Here's the 66-69 Toronado front wheel cylinder part #s. A quick Google will show you they interchange with some mid-60s A-bodies and, of all things, Novas. So not hard to find.
Grp 4.665, p/n 5469303 LH, 5469304 RH.
Rears: 4.665, p/n 5452329 fits both sides.
Rebuild kits:
Front 4.665, 5465083 both sides, 1-1/8" bore
Rear: 4.665, 5464848 both sides, 7/8" bore.
Old Nov 25, 2023 | 06:23 PM
Yeah the acdelco wheel cylinders were $9 each. I'd have rebuilt if they didn't make it so easy to be lazy.
Old Nov 25, 2023 | 06:53 PM
Jetmek's Avatar
I just got doing this job on mine today.
Getting the lower control arms back on was a BEAR
Old Nov 25, 2023 | 07:24 PM
torotoyguy's Avatar
It's been years ago, but I did a complete rebuild of my '66 Toro brake system, and I know I didn't have to pop any ball joints to replace the wheel cylinders. Replaced all wheel and master cylinders, all hoses, and all tubings except long front-to-rear line.as too hard to replace with its integration with the frame.
Old Nov 25, 2023 | 08:59 PM
Jetmek's Avatar
i had to replace a cracked lower control arm, bushings and lower ball joints as well as all 4 wheel cyls , hoses and all hard lines except one along frame
Old Nov 26, 2023 | 03:28 AM
ourkid2000's Avatar
Wow, that's a lot of work! Nice one!
Did you replace those front wheel bearings?
Old Nov 26, 2023 | 05:28 AM
Jetmek's Avatar
no just cleaned and insp seals. Ill prob be sorry later
Old Nov 26, 2023 | 05:50 AM
ourkid2000's Avatar
You can get em pretty cheap off Rockauto. The brand is WJB. I picked up a set and am gonna install em over the winter. God only knows if they're good quality but mine are original '66 bearings and I'd like to change em out. I have no idea how I'm gonna pull the bearings off that hub. I'd like to avoid cutting them off.
Old Nov 26, 2023 | 09:01 AM
Sugar Bear's Avatar
Changing the wheel cylinder shouldn't have affected the brake adjustment.
Old Nov 26, 2023 | 12:37 PM
torotoyguy's Avatar
You pull, actually push the bearings off the same way you'll be installing the new ones - you need a good hydraulic press and ideally the tool that grips the bearing right next to the hub.. Removal is harder than installation, probably the reason that GM stopped selling the bearing by itself, and instead started selling the bearing and hub as an assembly, using the same part number, 907770 if I recall correctly.
Old Nov 26, 2023 | 01:09 PM
ourkid2000's Avatar
Yeah, there's a whole bunch of things working against you right? If you're pushing the hub out the bottom with a shop press, you have to have either a huge receiver tube or else the space underneath the press has to accommodate a pretty big hub coming down as it gets pressed out. Typical homeowner style shop presses aren't usually that large. If you used a typical bearing separator/splitter, that's a pretty big bearing to try to pull with a tool like that. I guess that's why GM had that big ol' weird looking bearing puller tool shown in the manual.
It would probably be an easier job if the bearing stayed in the knuckle when you pulled the hub but it's doesn't look like that it what normally happens. The bearing always seems to be stuck to the hub.
Or of course you could always cut the thing off.....but I'd like to avoid that.
Old Nov 26, 2023 | 01:56 PM
Sugar Bear's Avatar
Disclaimer...I'm not familiar with these bearings and guess they are sealed. Has anyone tried either removing and reinstalling the seal if that is doable OR piercing the seal to allow old grease to escape and making another piercing on an opposite side injecting grease with a needle adapter. The piercings could be resealed with a dab of silicone.
I've had success removing and reinstalling the seals but I'm completely unfamiliar with these bearings.
Old Nov 26, 2023 | 02:13 PM
ourkid2000's Avatar
They have a metal ring seal, unlike the typical plastic grease sealed ones you're thinking of. It cannot be removed
Old Dec 6, 2023 | 04:42 PM
ourkid2000's Avatar
Hey Jetmek,
Think there's enough clearance on those wheel bearings to get a bearing splitter in behind to pull em off the hub? It's doesn't need much, just a little. I can't quite make out how much clearance is there based on your photos.
Old Dec 6, 2023 | 05:01 PM
Jetmek's Avatar
Ourkid2000. I think its do able Prob put it between retainer plate and flange. You would need to stack heavy bars or 1” plate to span the flange and set the splitter on. I would turn a piloted bar to center in the hub to push on. Of course you would need to do this in a press. A puller wont do
Old Dec 6, 2023 | 05:08 PM
ourkid2000's Avatar
Understood. How did you get the hubs out of the knuckle? Slide hammer? Did they fight ya?
Old Dec 6, 2023 | 05:45 PM
Jetmek's Avatar
One came out with a brass drift and BFH other one i had to put in the press if i recall. Re assembly i just made sure of no rust/ dirt. Heated knuckle up and dropped them in
recommend popping the dust seal out of the knuckle so it doesn't get damaged
kbdecatur
Apr 9, 2023 09:40 AM
VE6STA
Sep 6, 2021 06:49 AM
mattking
Wheels and Tires
Aug 11, 2021 02:47 PM
Bfg
Jul 16, 2021 05:21 AM
stan5
Sep 20, 2016 12:50 PM
