Do I have cornering lamps?
Old Feb 11, 2009 | 06:22 PM
sklbndt's Avatar
What are the physical identifiers that would indicate that a pair of turn signal assemblies from a 69 Toro have cornering lamps or not?
Old Feb 12, 2009 | 07:51 AM
sklbndt's Avatar
Got my answer...thanks.
Old Feb 12, 2009 | 02:29 PM
RATCHETMASTER's Avatar
"I reckon so!"
Why not post the answer??
Old Feb 12, 2009 | 03:12 PM
sklbndt's Avatar
That would make sense wouldn't it...sorry about that....
There will be three sets of wires and plugs. One for parklight/turn signal in pod's front pocket, then one for side marker light and one for cornering lamp in the pod's side pocket.
All of them have a boss cast into them for cornering lamps, but it's only knocked out if car had cornering lamps.
These will work on both 68 and 69. 68 lenses had a black outline stripe, 69 are all argent silver.
Credit goes to Rocketraider for the above information.
Old Feb 12, 2009 | 03:22 PM
Toro68
Guest
Posts: n/a
Just unscrew teh lenes, and see if there is two or three bulbs.
If ther eis three blubs - you and corncering light !
Old Feb 12, 2009 | 04:47 PM
sklbndt's Avatar
Ok.....now I'm confused since I've gotten two different answers.
Anyhow, I took the lense off and I have one amber bulb in the front pocket. In the side pocket I have a small amber bulb and a large clear bulb. Can anyone tell me whether or not these are cornering lights. I am thinking now that they are. Can someone verify this based on the info I have provided? Thanks in advance.
Old Feb 12, 2009 | 06:36 PM
rocketraider's Avatar
Oldsdruid
Sounds like a cornering light setup to me!
Yah, you could have just taken the lens off to start with, but I figured since they were already out of the car it would be as simple to look at the wiring, and you wouldn't risk having the lens gasket fall out in a dozen pieces!
Park/turn bulb is an 1157A, the side marker is a 97A, and the cornering lamp bulb is the elusive 1195- a single contact 50 CP bulb. Though it would not surprise me if they've been replaced with easier to find 1156's- common backup light bulbs, 32 CP.
pfb53
May 18, 2014 08:26 AM
m371961
Jan 12, 2013 06:21 PM
mugzilla
Dec 20, 2009 05:46 PM
grt05
Hurst/Olds
May 3, 2009 10:40 AM
