Anyone knowledgeable using Snap On MT2500 Scanner?
Is there anyone who knows how to use the Personality Keys using a Snap On MT2500 Scanner? If so, would you please leave a detailed message on how they are used. I know everything else about the scanner, I just don't know how to use the keys.
mt-2500 keys
I suppose you got your answer by now since your post was made in january or july (couldn't tell) - anyway, the keys for the mt-2500 scanner are for 1996 and newer vehicles - they fit in the obd II adapter and customize the different manufacturer specific pins in the 17-pin connector to work with the scantool. GM uses the K-9 key, fords use the K-2a and Chrysler uses the K-13 and the K-13a. I hope that helps. The tool will tell you what key to install when you enter the vin for every new vehicle you work on.
Jeff
Jeff
rhett838
Sep 24, 2013 01:55 PM
