'67 Toro Drum vs disc brake lines - are they *that* different?
I need to replace the cobbled together steel brake lines on my '67 Toro, and I find that Inline Tube has a disc brake set up available, but not a 4-drum set. The more I stare at the various manuals, the more I really can't tell them apart. MAYBE the line from disc to disc in the front could have different end points than the drum, but the remainder of the lines are the same - esp since the back brakes are always drums anyway. I only see one distribution block available, which looks the same as the one I have currently (most likely original). Other than the possible front line variance, is there anything that says I shouldn't order the "disc brake" lines for my drum brake car?
EDIT - I forgot to mention that when I spoke to the Inline representative at Homecoming, he was not able to provide me any information that would help.
Nothing to help you with your particular situation unfortunately, except to say that if an ILT rep DID have something to say about their part vs. your application, it would probably be wrong.
After my experience with their fuel line, I wouldn't rely on anything those guys say.
Yes, a '67 would have been 2-chamber from the factory regardless of whether it was disc or drum equipped, although the master cylinders would have been different.
With regard to ILT providing lines for disc brake cars only, my guess is that it's because while most '67s were originally drum-equipped, many owners these days want to retro-fit discs.
What lines do you want to replace exactly? The big differences are the master cylinder to distribution block line for the front brakes and the main line that runs from the distribution block to the rear of the car. Disc brake and drum brake cars use the same distribution block, but disc brake cars have two additional valves. There is a metering/ hold-off valve for the front. There is also a proportioning valve on the driver-side frame rail for the rear. So, drum brake cars would have a one-peice line going from the front master cylinder reservior to the distribution block, and a one-peice line going from the distribution block to the rear brake hose. On a disc brake car, those are both two-peice lines. Hope this helps.
Yes, I have drum brakes all around, but the only brake line set I see advertised is for disc brakes. I need to/want to replace the whole system, since all the lines are solid, crusty rust on the outside, plus the line along the driver's side front to back has two connectors in it that are obviously repairs from the past.
The problem is that the descriptions of the disc sets I've found didn't describe the included pieces like Loaded just did above. I think I've found a drum set through Jegs at a reasonable price based on his description of what should be there.
Maverick
Brakes/Hydraulic Systems
June 26th, 2013 08:21 AM
