66 Toronado Carburetor Picture Needed
Old Nov 17, 2014 | 12:00 PM
tarzangui's Avatar
Hi, I'm in the process of re-installing my Rochester Quad on my 66 Toronado. I just got it rebuilt and I want to put it on the engine myself.
My only problem is that there are a couple of hoses that I don't know where they connect to the carb. One hose is connected to a thin metal tube that runs from the back of the engine and the other is a rubber hose that also is connect to the back. Does anyone have a picture of their engine with these clearly visible so I can properly hook them up. Thanks
Old Nov 17, 2014 | 01:37 PM
hullinger's Avatar
See if either of these two pics help.
Old Nov 18, 2014 | 11:04 AM
tarzangui's Avatar
Thanks, that helps a bit.
However in the second picture you sent, just below the fuel filter there's a small square metal piece (part of the engine block) that has a plug in it. On my car that part is not plugged. It definitely had a hose attached.
It is attached to the same long hose you see at the bottom of the picture of your car that is running from the back of the engine into the front of the carb.
In my car, that same spot in front of the carb is blocked and the small square metal part is not.
Old Nov 18, 2014 | 11:40 AM
hullinger's Avatar
Pics of your engine would help but really, it sounds like vacuum is being fed from the intake manifold ports instead of the carburetor. Not a big deal for either the shift modulator on the transmission or the vacuum advance on the distributor. But, if you're going for factory correct than you'll want to reroute these vacuum hoses to the correct port. I'm more curious to know if the carburetor has been replaced, and if so, if that's why your hoses are rerouted. Also, the Toro has a unique carburetor throttle lever so even though other Q-Jet's will bolt on they don't have this correct throttle lever. This means the kick-down rod won't connect to the carb and so the Switch-Pitch won't work either.
Chris
Old Nov 19, 2014 | 06:12 AM
twintracks's Avatar
The vacuum advance should be connected to the manifold, the square piece you mentioned. The vacuum for the transmission vacuum modulator (the hard line) should be connected to the carb.
Old Nov 19, 2014 | 11:27 AM
tarzangui's Avatar
ok, thanks. I believe that's how it was originally set up. Also I didn't know the names of the parts. As soon as the weather gets a tad warmer I'll give it a try.
72455442RA
Apr 24, 2015 06:17 PM
Ronschwartzsr
Jul 14, 2014 05:27 AM
ignachuck
Feb 23, 2014 06:48 PM
66nicole66
Mar 9, 2011 01:36 PM
yeahbuddy
Jun 1, 2010 05:38 AM
