66 toro parts wanted
Hello All. I picked up a 66 toro survivor at the olds homecoming show here in lansing, mi back in june and could use some parts. First of all the correct carb, linkage rod (for cruise)? Intake mounted choke assy, valve cover breather, FM radio, ign. sw. ring nut, eng. oil dip stick(have tube) a/c muffler brkt., maybe a wheel opening mldg or two, cruise control, instrument panel parts such as the clear plastic lens, ign. sw ring nut, lower brushed alum. trim apliqays for he switches Also I could use a replacement elect seat track rear jack screw gearbox. The worm gear is stripped. Thanks, Jeff "The Toronador, safe at any speed"
Here's one I found on craigslist, Indianapolis, Indiana. Not to far from you.
http://indianapolis.craigslist.org/cto/3983150754.html
twintracks
June 28th, 2010 06:26 AM
oldsmobilia
Brakes/Hydraulic Systems
April 18th, 2010 07:43 AM
mark77301
November 11th, 2008 10:49 PM
