66 toro parts wanted
Old Aug 15, 2013 | 04:22 PM
jeffo's Avatar
Hello All. I picked up a 66 toro survivor at the olds homecoming show here in lansing, mi back in june and could use some parts. First of all the correct carb, linkage rod (for cruise)? Intake mounted choke assy, valve cover breather, FM radio, ign. sw. ring nut, eng. oil dip stick(have tube) a/c muffler brkt., maybe a wheel opening mldg or two, cruise control, instrument panel parts such as the clear plastic lens, ign. sw ring nut, lower brushed alum. trim apliqays for he switches Also I could use a replacement elect seat track rear jack screw gearbox. The worm gear is stripped. Thanks, Jeff "The Toronador, safe at any speed"
Old Aug 15, 2013 | 10:48 PM
65B01Delta's Avatar
Here's one I found on craigslist, Indianapolis, Indiana. Not to far from you.
http://indianapolis.craigslist.org/cto/3983150754.html
vistacruiser1971
Dec 27, 2012 07:35 AM
handsomened
Apr 29, 2011 09:09 PM
twintracks
Jun 28, 2010 06:26 AM
oldsmobilia
Brakes/Hydraulic Systems
Apr 18, 2010 07:43 AM
mark77301
Nov 11, 2008 10:49 PM
