455 pulleys
Old Nov 21, 2007 | 08:09 AM
ratsglass29
Guest
Posts: n/a
455 pulleys
Can you guys tell me the part #'s for the crank and water pump?
motor has a/c, alt and power steering.
I have some pulleys however can't seem to make anyhting work or line up
Rick
Old Nov 21, 2007 | 09:35 AM
2blu442's Avatar
pulleys
Hi Rick
Can you give us a little more information? What is the engine out of and what are you putting it in? Do you already have a pulley on the power steering pump? Does it have one or two grooves? John
Old Nov 21, 2007 | 12:15 PM
Rick
Since this is in the Toro section, should we assume the engine is in a Toro? Where did you get the brackets? Toro motors used different accessory brackets than RWD Olds motors. Also, Olds water pumps come in three different lengths and the pulleys MUST match the water pump. Finally, be sure all the spacers are in place between the PS pump bracket and the block.
Old Nov 22, 2007 | 02:19 PM
ratsglass29
Guest
Posts: n/a
455 pulleys
Rick
Aftermarket
Main Entry:
af·ter·mar·ket
Function:
noun
Pronunciation:
-"mär-k&t
1 :Does not fit
2 :
the market for parts and accessories used in the repair or enhancement of a product (as an automobile)
Old Nov 22, 2007 | 02:22 PM
ratsglass29
Guest
Posts: n/a
sorry about hat
sorry for the confusion on this , i posted in the part of the forum
I reposted it in the 442 part
Rick
Aftermarket
Main Entry:
af·ter·mar·ket
Function:
noun
Pronunciation:
-"mär-k&t
1 :Does not fit
2 :
the market for parts and accessories used in the repair or enhancement of a product (as an automobile)thanks Rick
Old Nov 22, 2007 | 02:38 PM
ratsglass29
Guest
Posts: n/a
455 motor don't know what it is out of or yr
Going into what was a Cutlass conv. when we drove it in and driving out a 442
Power steering
I have both pumps(saginaw and one with round resivor and oval neck) and two sets of brackets one pump was bolted to each
No spacers on P/S brackets
Looks like one goes between the brackets and betwwnthe back half of the bracket and the timing cover
Can you tell me the lentghs and dia. of these and are suppost to be more
Two different alt. brackets---
1. goes over the valve cover and ties to the bottom section which attaches to the head bolt and looks like it needs spacers behind it to bolt to the head
2. bolts to the head and intake(top half) and exhaust front hole, P/S bracket and has a long skinny bracket that comes off the front hole on this bracket
Cast A/C brackets--half goes over the vavle cover and half bolts to the head
Have the front and rear brackets for the A-6 compressor
Thanks again Rick
Old Nov 22, 2007 | 06:54 PM
Power steering
One (about 3/4" thick) goes between the bottom rear bracket and the side of the block. The other is tubular and goes over the bottom of the two studs on the front cover.
Thanks again Rick
Get a factory service manual. It will show the correct type and orientation of the brackets. Note that the alternator brackets come in two flavors, A/C (alt on the driver's side) and non-A/C (passenger side). Also, as I noted before, Toro brackets are different from RWD brackets.
By the way, the 350 and 455 brackets are exactly the same. Were required due to the deck height differences, the brackets have two sets of holes.
Old Nov 23, 2007 | 07:31 AM
Oldsguy's Avatar
Past Administrator
THREADS MERGED
Old Nov 23, 2007 | 01:32 PM
ratsglass29
Guest
Posts: n/a
Is the factory service manuel the one they use on the line to assemble the car shwing everything from chassis to paint?
if so I have one of those from opgi and don't see antthing in it
rick
Old Nov 23, 2007 | 01:59 PM
rick
No. It's actually called the Chassis Service Manual and it should be the first thing you buy for the car. By the way, I'm pretty sure the diagram is also in the assembly manual that you refer to, however all of those are reprints and some are more complete than others. Look for the section called "Engine Dress".
Old Nov 23, 2007 | 06:48 PM
ratsglass29
Guest
Posts: n/a
Thanks Joe
Where is the best place to get a copy of the chassis service manuel
Rick
Old Nov 23, 2007 | 07:08 PM
kevinkpk's Avatar
Thanks Joe
Rick
I can't say this is the best place, but I got a replica chassis service manual off ebay for 70 bucks. I also had a friend donate a Fisher body manual (original) for nothing. The replica manual is just that (now with some dirty pages, especially in the carburetor section), but thats why I bought it. There may be other places to find one. Only problem I have with mine is the electrical schematic, it is a black and white copy, and I cannot read it.
I thought at one time there was a link for service manuals on this sites main page?
Dave Siltman
Jul 24, 2014 02:55 AM
mauls
Sep 19, 2010 04:42 PM
STR-8_CHARGIN
Aug 13, 2010 04:25 PM
69deltaconvert
Nov 7, 2006 10:25 AM
TOONLOVESCHERYL
Jul 4, 2006 08:07 AM
