Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Oil pressure hose broken
Old Nov 18, 2014 | 03:51 AM
koen2k's Avatar
the hose from my oil pressure gauge is broken. I now wish that linking only the hose is thickened by the pressure. Now I get the gold nut not through the tubing. does anyone know how I get through it again or do I need a new hose which is not expelled, Thanks, sorry for my bad english
Old Nov 18, 2014 | 04:00 AM
You will need a new compression fitting. You can buy them at your parts store or you can get a new line kit. They sell the line kits in plastic and metal.
Old Nov 18, 2014 | 05:52 AM
koen2k's Avatar
Thanks for youre reply, i cant heat the old line and put it back on?
Otherwise i will buy a new line
Old Nov 18, 2014 | 06:20 AM
The compression fitting ferrule crushes on the line when tightened, so you can't reuse it. If you buy a new fitting you can repair it and use the old line.
Old Nov 18, 2014 | 07:03 AM
The ferrule is really the only part that you need. It is consumable and can only be used on one line - once it is tightened, it will not come off and cannot be reused on another line.
The nut and the fitting screwed into the engine can be reused.
Google «⅛" compression fitting ferrule».
This may be a good time to switch from nylon to copper tubing, which should be more durable.
Old Nov 18, 2014 | 08:13 AM
Personally, I'd be more worried about that short section of hose from the thermostat housing to the water pump. That doesn't look too healthy, either.
Old Nov 18, 2014 | 09:07 AM
Octania's Avatar
My first thought too
so, what is that OTHER huge horizontal hose and the other smaller hose protected by a piece of old heater hose?
Old Nov 18, 2014 | 09:23 AM
I believe his car runs on propane, hence the extra hoses.
Old Nov 18, 2014 | 09:25 AM
From his other thread, the car is a 73 D88 with a propane conversion. The smaller horizontal hose looks like the ones coming out of the propane tanks in his trunk, so I'm assuming that's what it's for. The larger radiator-ish hose is a mystery. Hot water heating for the propane carb?
Old Nov 18, 2014 | 10:03 AM
koen2k's Avatar
Haha true, i replaced that hose, during that i broke the oil gauge
koen2k's Avatar
Thats true
Old Nov 18, 2014 | 10:04 AM
koen2k's Avatar
thanks Eric, i found one
Old Nov 18, 2014 | 10:07 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Jegs and Summit among others sell the line and fittings in a kit. I like copper line vs plastic.
Old Nov 18, 2014 | 04:34 PM
Lady72nRob71's Avatar
Since that section broke, you can bet it may be waiting to break elsewhere, too. Inside the car would be even worse! I broke the one on my old Ford when changing oil, so I replaced the whole thing. it was over 2 years old anyway - plastic turns brittle over time. Tape the end of the new tubing to the old and just pull it gently through. Use grommets where it is up against holes or such. Do not overtighten the nuts though - easy to do with nylon or thin copper.
Old Nov 28, 2014 | 02:48 AM
koen2k's Avatar
I finally received my new kit. the new lock ring fits easily on the wire. I'm afraid if i attach it now wants to slip. Am I wrong?
The hose must not be linked through the left fitting right?
Old Nov 28, 2014 | 03:50 AM
When you tighten the nut, the ferrule will compress against the tubing and become tight, which is why it's called a compression fitting.
The tubing pushes into the base portion as far as it will go, then the nut is tightened, compressing the ferrule.
I'm not sure what you mean by "linked."
And you do have only one ferrule on there, right? It almost looks like two, back-to-back.
Old Nov 28, 2014 | 05:22 AM
koen2k's Avatar
Thanks for your answer Eric,
Yes its tight now i figured it out
With linked i mean connected.
there is only one ferrule, i thought the same, but its new, they dont have the old ones back to front
Sampson
Mar 24, 2015 09:33 AM
foreverolds
Dec 1, 2012 07:07 PM
knighthawk
Body work
Mar 16, 2011 09:05 AM
Railguy
Tech Editor's Desk
Jul 25, 2010 02:36 PM
