Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
intake manifold ID
Old July 4th, 2011, 03:59 PM
Bob Kelso's Avatar
intake manifold ID
I have a cast iron intake manifold with the casting numbers 380059 . I cant find this number in any of my reference materials , any ideas ? It is a small block olds with the Carter carb bolt pattern,thanks. BOB
Bob Kelso is offline
Old July 4th, 2011, 07:53 PM
A square bore intake for an SBO would have to be from a 1964-65 330. The carb was a Rochester 4GC. The 380xxx casting numbers are consistent with the 1964 model year, so I'm going with that - a 1964 330 intake.
joe_padavano is offline
Old July 5th, 2011, 05:00 AM
Bob Kelso's Avatar
Thanks for the info , where did you find the casting numbers info ? BOB
Old July 5th, 2011, 07:05 AM
Well, from the various lists of intake casting numbers that are around, I see that 381920 is from a 1965 330 and the numbers are generally associated with model years (390327 is a 1966 casting, for example), so I'm guessing that 380059 is a 1964. It can't be any earlier than that, since 64 was the first year for the SBO.
Old July 5th, 2011, 07:50 AM
"Car"mudgeon
GAOldsman's Avatar
There are a few on the internet for sale as well. One is listed as a '64 442 intake, but I would imagine it would be for any '64 330 engine with the 4 bbl option.
GAOldsman is offline
shamusj
December 18th, 2014 09:28 AM
svnt442
July 17th, 2011 04:43 PM
jjatich
July 29th, 2007 07:57 PM
SMOKEYMTNKUSTOMS
October 12th, 2006 12:18 PM
magnusdog
September 2nd, 2006 10:01 PM
Quick Reply: intake manifold ID
