Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Inconsistency In Tech Info.
Old May 3, 2011 | 08:07 AM
InfoJunkie's Avatar
InfoJunkie
ID/ Casting
Code Year(s) CID CCs Number Notes
1 '64 330 385101 Used ROCKER SHAFTS rather than
pairs on PEDESTALS
ID Casting # Combustion Camber Intake Valve Exhaust Valve 1 385101 The rocker assembly is the same as later non-adjustables, except the aluminum cross pieces are stamped steel, and don't bottom out on the head. The pivots are individual and made of steel; they are linked together by the steel cross piece. These are adjustable rockers.
While one section says 64 330 cid heads were all shaft mount,further down the same page says they were like the pedestals only adjustable. This just doesn't seem accurate to me.
Old May 3, 2011 | 09:32 AM
rocketraider's Avatar
Oldsdruid
There was a running change in July 1964 where about 2000 1964 330 cars got #2 heads, which are bridge/pedestal-style as all 65-later are. All 330 production prior to that date had #1 heads which had rocker shafts.
Info from 1964 Tech Bulletins and Dealer Information Letters.
Triton1968
Nov 5, 2012 02:55 PM
sx455raidercelticfan
Aug 1, 2010 08:03 PM
SPEEDROCKET
Dec 18, 2007 06:35 PM
vinoberg
Nov 12, 2006 04:56 PM
Oldsguy
Apr 24, 2006 07:43 AM
