Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Sloppy steering 1963 Olds F 85
Old May 28th, 2018, 05:18 AM
Swisspeter's Avatar
The ball Joints in the center link are worn, so I would need a replacement. I have already searched the usual sources, to no avail. Can someone help? Would it be possible to replace the ball joints?
The rules and regulations are very strict here in Switzerland and I would hate to take a otherwise perfectly runnig car of the street.
Thanks, Peter
Swisspeter is offline
Old May 28th, 2018, 05:40 AM
Thanks, Peter
Kanter sells all the front end parts.
joe_padavano is offline
Old May 28th, 2018, 08:51 AM
Swisspeter's Avatar
I found parts for the full size cars only in the Kanter catalogue and nothing for the 1963 F 85. I've sent them a email and am now hoping for the best
Old May 30th, 2018, 08:43 AM
Kanter's front end kit for a 1963 F-85
Kanter Idler Arm for 1963 F-85 (second one down)
The center link uses integral adjustable ball fittings that are not replaced. You use a drag link socket to adjust them.
Old May 31st, 2018, 02:24 AM
Swisspeter's Avatar
Thank you for the advice
Old July 30th, 2018, 07:59 AM
Swisspeter's Avatar
I found a refurbished part at usapartssupply.com and it fits perfectly.
Peter
Classics65
February 3rd, 2017 07:53 AM
John1963
July 1st, 2015 08:20 PM
delta88_frankfurt
March 7th, 2015 07:54 PM
66olds98conv
Ninety-Eight
May 14th, 2013 06:57 PM
1k442
March 4th, 2011 07:38 AM
Quick Reply: Sloppy steering 1963 Olds F 85
