Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Pop a TH400 PAN
Old Jul 9, 2020 | 04:29 PM
11971four4two's Avatar
MOTORHEAD
Pop a TH400 PAN
Old Jul 10, 2020 | 03:32 PM
Tedd Thompson's Avatar
Tell me more..... Tedd
Old Jul 10, 2020 | 07:06 PM
MOTORHEAD
HEY TEDD
I thought I purchased a "stock" TH400
I pulled off the pan and this critter has been "modified"
I hoped that maybe a resident "expert" could tell me more by perusing the pictures
It was an automatic from the factory and now it is a manual transmission
Have a Good Week end
b
Old Jul 12, 2020 | 07:21 AM
Thanks Brian, I know little of these new modern cars...... Lost in the fifties ...Tedd. You all be good or at least don't get caught..
Old Aug 17, 2020 | 03:41 AM
RWK's Avatar
RWK
Well glad to see a finishing nail holding the shift shaft, thought mine was the only one! thought I was looking at my picture. 72 TH400 in my 88. I replaced with a cotter pin, figured it was lost by previous mech and the nail was handy!
Finishing nail?
Old Aug 17, 2020 | 05:44 AM
Hydromatic used finishing nails to retain the manual shaft in the trans. They also used nails for the pivot shafts for the governor weights on the 400, 350, 700, 250, etc. GM spared no effort looking for ways to save money! I guess it was cheaper for them to buy nails instead of machining retaining pins or pivots.
Old Aug 17, 2020 | 06:18 AM
The "finishing nail" is factory. Most of the TH400s I've had apart were the same. The only "modification" I see in the photos is that the kickdown solenoid wire is not connected to the pass-through terminal in the case.
Old Aug 17, 2020 | 07:06 AM
TripDeuces's Avatar
Those two pipe plugs don't look stock. Where are the lines?
Old Aug 17, 2020 | 07:10 AM
Good catch. I missed that.
Old Aug 17, 2020 | 12:21 PM
MOTORHEAD
This MUST BE REAL says
Old Aug 17, 2020 | 12:26 PM
That appears to be a home made manual valve body. The pipe plugs are blocking the govenor feed and return ports in the valve body. I’m guessing your also going to find a small hole drilled right above the return passage, the idea is to loop governor oil to the shift valves.
I’m curious to know what’s been done to the 2-3 accumulator and intermediate servo. I can see the pin for the accumulator piston has been removed. I can also see the vent hole in the 1-2 shift valvetrain is open, for the poor man homemade manual valve body to function that hole needs plugged, and the shift valve needs a vent ground into it.
Old Aug 17, 2020 | 12:33 PM
MOTORHEAD
I sold it AS IS no longer own this transmission
I was tired of the external mod Guessing game
AINT STOCK
oldcutlass
Jun 5, 2022 03:01 PM
Jul 10, 2020 04:19 PM
2blu442
Feb 22, 2019 10:29 AM
dream66
Body work
24
Aug 12, 2017 02:20 PM
WolfmanG
Jan 16, 2012 03:26 PM
