Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Pertronix Electronic Ignition
Old Feb 18, 2017 | 05:20 AM
ranmat2's Avatar
I am attempting to convert the distributor on my 1955 Olds to Pertronix Electronix parts. The installation chart indicates the ballast resistor on this car should be removed. That being the case are the yellow and black/brown wires previously routed through the ballast (which lead to the ignition switch & the starter) supposed to be connected to the positive side of the Pertronix Flame thrower Coil?
Old Feb 18, 2017 | 07:09 AM
redoldsman's Avatar
Proud Viet Nam Veteran
If you want to leave the resistor there for looks, just connect the Pertronix to the primary side which has a full 12 volts.
Old Feb 18, 2017 | 09:49 AM
ranmat2's Avatar
Old Feb 18, 2017 | 05:29 PM
ranmat2's Avatar
If I decide to not leave the resistor there do I connect yellow and black wires (my understanding is the yellow goes to the ignition switch inside the car and the black to the starter) to the coil. And if so yellow goes to positive and the black to the negative?
Old Feb 18, 2017 | 05:41 PM
ranmat2's Avatar
If I decide to NOT leave the resistor in place do I connect the yellow & black wires from wiring harness (my reasoning is the yellow wire would be connected to the positive side of the coil and black to the negative side of the coil? Thanks for your help.
Old Feb 18, 2017 | 08:37 PM
redoldsman's Avatar
I don't remember the color of the wires. I will try and look at my car tomorrow.
Old Feb 18, 2017 | 08:57 PM
This should help, move both wires that go to the resister to either terminal. Leave the stock power wiring to the coil and add the igniter wires as per the center diagram.
Old Feb 19, 2017 | 04:18 AM
ranmat2's Avatar
Thank you so much. This helps tremendously.
Nails
Dec 23, 2015 04:37 PM
Jen
May 23, 2012 10:44 AM
442Dave
Jan 7, 2012 07:28 AM
atkinsom
Nov 21, 2011 09:40 AM
matt68
Sep 11, 2009 05:19 PM
