Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
No start
Old October 2nd, 2021 | 04:19 PM
boamridge's Avatar
No start
Can anyone share with me what possible could be wrong as I put the positive cable on the positive side of battery then I got a pop sound, I go to crank the car and nothing. I checked the votage and it seens to be charged.
I went back to under the hood to trace wire just in case as I had previously had to change the oil piump. So I had to jack the engine up and take the starter off. I did notice the brown wire coming from the HEI on the tach side along with another wirewith 2 wire joined together that was loose . The wires appeared to be coming from some type of connector that is mounted on the firewall.
I saw the screw still in place so I placed both of them back where I thought they went but still nothing. Please see pics Hope this was clear enough so CO member can help
Old October 2nd, 2021 | 04:51 PM
RetroRanger's Avatar
72 Olds CS
Year and model ?
also the resistor (where youve attached the wires). Was likely used w points and it looks like you have an HEI.
Do you have spark? Can you tell where those wires goto? Its possible someone. Just attached wires together there to isolate them and join them together but we will need more info on whats been done to the car.
Old October 2nd, 2021 | 06:40 PM
boamridge's Avatar
69 350 rocket
one single wire comes from the tach side of the HEI and it is brown
the other wire is two joined together with ine connector and it seems to begoing down to the starter
Old October 2nd, 2021 | 06:42 PM
boamridge's Avatar
Wow sorry for the late response but there is no spark or click from starter.....just heard the pop sound when I connected the positive cable
Old October 2nd, 2021 | 06:52 PM
PatL's Avatar
sounds like a short. May want to check any loose wires that are grounding out
Old October 3rd, 2021 | 07:26 AM
The problem could be one of a bazillion possible causes. Get a test light and Chassis Service Manual wiring diagram and figure out where the power stops. Start with any half-fast "custom" wiring like those cheesy crimp connectors.
Old October 3rd, 2021 | 08:19 AM
stellar's Avatar
I don't have a wiring diagram, but if you heard a pop I would look for a blown fuse or fuselink.
Old October 3rd, 2021 | 08:32 AM
boamridge's Avatar
Hey Joe you might be on to something .....my starter wire connectors needed to be replaced so I replaced them with new connectors for the R and the S side of starter ....I gues I may need to look at those to make sure thet are connected but man what was that pop sound
Old October 8th, 2021 | 06:24 PM
boamridge's Avatar
Update................ I replaced starter with new ( manufacture replacement) and made sure the purple wire went to the S side......the yellow went to the R side then I tighten both wires that were tied in together which connnected to resistor
Old October 8th, 2021 | 07:55 PM
What was the result of your above update, did it start and run?
Old October 8th, 2021 | 08:06 PM
boamridge's Avatar
Yes......simple error .....starter wirewere in wrong place and bad starter......now I have low oil pressure .....start out around 40 then drops over idling time to low as 5.......
Old October 8th, 2021 | 08:25 PM
72 Olds CS
Eh the low oil pressure isnt huge, unless its a fresh rebuild. Many other posters have said they have had LOP foryears w out issue.
some run a thicker oil if climate allows, as long as the LOP isnt caused by something other than normal wear., like no oil, or clogged pump etc.
Old October 8th, 2021 | 09:46 PM
boamridge's Avatar
Thanks for reply and I have heard the same....from alot of 350 olds owners and just in general of older engines.....so not a rebuild just oil change with thicker oill ....oil pump seem to be doing it job.....on rev ups the mechanical gauge appears to be normal....but it idles to a loping sound....car has been sitting.....so not sure if the hei distributor may need adjusting for better timing .....
Old October 9th, 2021 | 10:53 AM
If it’s a high mileage untouched engine the timing chain is probably way overdue to be replaced. The nylon covering on the cam gear crumbles and collects in the oil pan, clogging the oil pump pickup. The engine is then starved of oil. its all downhill after that.
Old October 9th, 2021 | 05:27 PM
boamridge's Avatar
Timing has been changed about 4 years ago with little to no miles driven afterwards........just recently dropped oil pan to view the oil pump and all looked well but I didnt change out pump also no shavings in oil pan
Old October 9th, 2021 | 05:41 PM
70W-32's Avatar
Whats you idle speed and ignition timing
Old October 10th, 2021 | 09:57 AM
boamridge's Avatar
Not sure if ideal speed and timing ……I am going to have my distributor checked and make sure it doesn’t need an adjustment for retardant
Old October 10th, 2021 | 11:30 AM
rocketraider's Avatar
Oldsdruid
I just read this thread, and combined with the charging and starting problems in your no start thread, looks like your 69 has been the victim of some wiring buggery. Not unusual on a 52 year old car and all the more reason to get that factory service manual with wiring diagrams so you can straighten it out.
That pop you heard was an electrical load powering up. Do you have aftermarket stereo, lighting or anything running off the battery? Were the car doors open (dome lights on) when you landed the battery cable?
With HEI, at minimum that add-on ballast resistor needs to be out of the picture as it serves no purpose for HEI.
nelsontj
December 30th, 2021 09:07 AM
Rosco920
August 3rd, 2018 10:16 AM
coppercutlass
May 4th, 2015 09:02 PM
442_Mustang
July 21st, 2009 03:43 PM
The_Jeremiah
December 6th, 2007 10:17 AM
Quick Reply: No start
