Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
need tech info 1950 303 fuel pump and carb
Old Aug 28, 2019 | 04:05 PM
al1950's Avatar
I have 1950 303 . I need
1.fuel pump instruction sheet or drawing showing how to rebuild with a kit,
2. carb instruction sheet or drawing showing how to rebuild with a kit,
any advice or help where to look appreciated. Allan Ladd
Old Aug 28, 2019 | 05:51 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Allan:
The best thing you can do is buy a factory shop manual. It will serve you well in everything you do with this car. You can find them on ebay. Be sure and get an original one with some greasy fingerprints on it. Do not get the reproductions or the ones on CD. They should be about $30-$35. If you need an air cleaner for that car. I have one.
Old Aug 28, 2019 | 06:54 PM
Charlie Jones's Avatar
Phantom Phixer
Fusick Automotive has what you need .
Fuel pump kit ;
http://www.fusickautomotiveproducts....?number=FPA183
There were two different kind of carbs used in 1950 . Carter and Rochester , Fusick has both , on this page ;
http://www.fusickautomotiveproducts....s.asp?dept=981
The kits should come with instructions . As mentioned , a shop manual is also recommended ;
https://www.ebay.com/sch/i.html?_fro...963+oldsmobile
Old Aug 28, 2019 | 06:57 PM
al1950's Avatar
thanks a lot , this will help me get started, ordered kits ,
Old Aug 29, 2019 | 09:01 AM
al1950's Avatar
Allan:
can you send me pic of air cleaner and price?
also do you know where I can find trim tag code info, mine shows
style+50-3711d
trim =3
paint = 11
ACC blank
TOP blank
thanks Allan
my email is LADDLLL@yahoo.com ph 386 453 1602
Old Aug 29, 2019 | 06:39 PM
Phantom Phixer
Style 50-3711D = 1950 Futuramic 88 Deluxe two door sedan .
Trim 3 = no info
Paint 11 = Adler green metallic https://www.autocolorlibrary.com/pag...ile-Car-Colors
Old Aug 29, 2019 | 06:47 PM
al1950's Avatar
Trim 3 = no info
thanks for that, I found the trim , it is silver 2 tone material.
INTRUDER
Ninety-Eight
Nov 13, 2015 05:48 PM
jims2000lt
Jul 7, 2012 11:20 AM
oldolds88
May 26, 2012 09:22 AM
lluebke
Apr 28, 2012 05:10 AM
Captain_Fish
Mar 2, 2011 04:30 PM
