Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Need correct posi model number for 68 442?
Old Dec 31, 2019 | 12:45 PM
matt506's Avatar
Does any one here know what number for Eaton or any well known axel makers for a 12 bolt cover 31 spline 3.42 gear rear end? Car is a 1968 442 with m21 455 engine. It is the original 3.42 gear 12 bolt cover rear axel with 31 spline axel shafts. I see a lot but am getting confused as they say one thing but show a 10 bolt cover picture. Other just say BOP but don’t elaborate wether 10 bolt is the cover or ring gear. Thanks Matt
Old Dec 31, 2019 | 06:56 PM
Your axle is a Type O, used only in 1966-1970 Cutlass models. Most of the mainstream differential suppliers do not support this axle. It has a twelve bolt cover but only a ten bolt, 8.5" ring gear, and no, it is not the same as the 8.5" Chevy ten bolt axle. Be sure any differential you get for this axle is for a Type O. If the vendor doesn't know what that is, move along. Some aftermarket suppliers actually modify the differential from a Ford 8.8 to fit the Type O.
Old Jan 1, 2020 | 07:41 AM
matt506's Avatar
Thanks I know about the Chevy ones not being the same. I see a lot of guys swap the whole axel to Chevy ones but would like to stay original. I guess my best bet is just callling some of these guys on the phone direct.
Old Jan 1, 2020 | 07:49 AM
Here's one source.
Jim at JDRace is another. Contact monzaz on this site. Actually, I suspect Jim will jump in here when he stumbles over this thread.
jimbr70
Jun 23, 2017 05:50 PM
wyocutlass
Drivetrain/Differentials
Feb 22, 2017 05:12 PM
johnnyjaws
Mar 15, 2014 08:00 AM
Chevyguy
Oct 7, 2013 04:55 PM
bosch 68 442
Apr 10, 2011 09:04 PM
