Help from someone with lots of manuals
Captain of my ship
My problem is that I cannot find any other year or model Olds that have the same stone shields as my 69-98 convertible. Mine has headlight supports that are made from plastic , the same as the stone shields , and the shields bolt on at the nose and the supports. I have the 69 service manual and it does show this setup so I know it's right. I have tried getting them from a 69-88 and 70-98 convertible but they are different. Does anyone know if there are any other 69 models that are the same or any other year that I can use? So far I have not found any info.
The ones you have don't look all that bad aside from what appears to be some somewhat minor appearing issues with plating. If you just need a re-chrome you might want to take a look at the rather inexpensive and easy to use kits you can get from Caswell Plating ( http://www.caswell.com ). Might be a faster way to get to where you need to go.
Sorry, I hadn't checked this out sooner for you, Wolfman98. '69 98s are it. Not surprisingly. Back then quite a bit of difference from year to year.
I agree with Texascarnut that yours look quite serviceable. There's no "chrome" on any of it is there? If not, no need to get plated even. Plastic fill and sand to shape as needed. Then paint with the correct color silver (argent, is it??). Works great, and small flaws not even visible when installed.
Captain of my ship
![Smile](https://classicoldsmobile.com/forums/images/icons/icon7.gif)
Thanks for the reply's it helps to know what I should be looking for. The left one is missing the piece that attaches to the nose and the right one is missing a small piece close to where it attaches to the support for the headlight. If both sides were whole then I could fix them but both sides are missing pieces so I thought I would see if anyone had some that were complete regardless of the condition as they can be fixed.
1965CUTLASSHOLIDAY
May 30th, 2010 03:55 PM
