Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Help from someone with lots of manuals
Old Jun 1, 2009 | 04:52 AM
wolfman98's Avatar
Captain of my ship
My problem is that I cannot find any other year or model Olds that have the same stone shields as my 69-98 convertible. Mine has headlight supports that are made from plastic , the same as the stone shields , and the shields bolt on at the nose and the supports. I have the 69 service manual and it does show this setup so I know it's right. I have tried getting them from a 69-88 and 70-98 convertible but they are different. Does anyone know if there are any other 69 models that are the same or any other year that I can use? So far I have not found any info.
Old Jun 1, 2009 | 05:16 AM
Oldsguy's Avatar
Past Administrator
To encourage you to keep at it. My '69 88 had the same configuration and it was a 2DR hardtop, so I know they are out there. Good luck.
Old Jun 1, 2009 | 07:01 AM
Oldskeeper's Avatar
Hi wolfman98,I would hit yellowstatue up for any info,he has an excellent resource and vast supply of knowledge and books about the full size olds and cutlass too.
Steve
Old Jun 1, 2009 | 10:28 AM
Texascarnut's Avatar
Geezer
The ones you have don't look all that bad aside from what appears to be some somewhat minor appearing issues with plating. If you just need a re-chrome you might want to take a look at the rather inexpensive and easy to use kits you can get from Caswell Plating ( http://www.caswell.com ). Might be a faster way to get to where you need to go.
Old Jun 1, 2009 | 07:06 PM
wmachine's Avatar
Trying to remember member
Sorry, I hadn't checked this out sooner for you, Wolfman98. '69 98s are it. Not surprisingly. Back then quite a bit of difference from year to year.
I agree with Texascarnut that yours look quite serviceable. There's no "chrome" on any of it is there? If not, no need to get plated even. Plastic fill and sand to shape as needed. Then paint with the correct color silver (argent, is it??). Works great, and small flaws not even visible when installed.
Old Jun 2, 2009 | 02:51 AM
Yellowstatue's Avatar
Smile Vast-My donkey
Olds 350-360-380; PN 401742-right; PN 401743-left; 69 only! So your car is a 380 and the others are 88's, so any '69 88 or 98 will fit your car...
Old Jun 2, 2009 | 03:12 AM
wolfman98's Avatar
Captain of my ship
Smile Thanks
Thanks for the reply's it helps to know what I should be looking for. The left one is missing the piece that attaches to the nose and the right one is missing a small piece close to where it attaches to the support for the headlight. If both sides were whole then I could fix them but both sides are missing pieces so I thought I would see if anyone had some that were complete regardless of the condition as they can be fixed.
Old Sep 21, 2009 | 12:59 AM
AZ Rocket88man's Avatar
I agree with Kurt. They look plenty good for re-use. The best color I have found for this use is Krylon Dull Aluminum.
Joe Varley
AZ
Cathys88
Apr 13, 2014 10:26 AM
72cuttthang
Jan 16, 2012 03:17 AM
1965CUTLASSHOLIDAY
May 30, 2010 03:55 PM
jcombest
May 25, 2010 05:04 AM
unrelatedbrothers
Jun 25, 2009 02:32 PM
