Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Cranks
Old Jan 15, 2020 | 06:13 PM
Doug Carner's Avatar
69 Ol' Blue
Cranks
Are the auto and manual trans cranks any different?
Old Jan 15, 2020 | 06:22 PM
Yes, the manual crank is drilled for a pilot bearing the auto cranks have to be drilled.
Old Jan 16, 2020 | 02:12 AM
69 Ol' Blue
Thank you sir!
Old Jan 16, 2020 | 08:13 AM
Just to be clear, within a given year and application, the casting or forging is the same. The only difference is that MT cranks have had the bore machined for the pilot bearing. It is common to have an AT crank machined to use it in an MT application.
Old Jan 16, 2020 | 10:54 AM
OLDSter Ralph's Avatar
Where did this print come from ? I saved it from a post on this site, a while back.
Old Jan 16, 2020 | 10:58 AM
I'm pretty sure that's the one in the Mondello handbook. Note that the one I posted shows the details of the snap ring groove for the later motors that retained the roller bearing with a snap ring. Your drawing is for the pressed-in version. The key dimension is the bore for the bearing itself. Yours has 1.3770-1.3775 for the pressed bearing. Mine has 1.378-1.380 for the snap ring bearing.
Old Jan 16, 2020 | 11:08 AM
Thanks for the clarification and new print. I did save the recent one also. I like to have correct information and this new print caught me off guard. Do you know the snap ring part number ?
Old Jan 16, 2020 | 11:24 AM
Snap ring part number is 9425556, but you are unlikely to find a GM one. It's a 1 3/8" snap ring for an ID application, available from McMaster Carr, MSC, Fastenal, etc.
Old Jan 17, 2020 | 03:09 AM
Thanks Joe P
Delasangre4231
Aug 7, 2018 11:59 AM
1971 442 convert
Jun 13, 2015 02:37 PM
citcapp
48
Mar 30, 2014 03:40 AM
oldsmosteel
Apr 28, 2013 12:39 PM
