Coil OHM for 442 W30
What is the orig OHM spec of the coil for a '71 442 W30?
Have a new Pertronix 40011 12v 1.5 OHM coil on the shelf. Wondering if i should use.
UPDATE - FOUND SPECIFICATIONS
-Main PowerLine had a 1.35 ohm Resistance Wire
-Secondary PowerLine from the Starter had NO Resistance Wire. Designed to give the engine a little extra boost at startup
Looks like my 1.5 ohm Coil is just what THE DOCTOR ORDERED
