Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Carburetor Heat Shield. What Kind?
Old Jun 29, 2020 | 07:56 PM
OttoSkorzeny's Avatar
I have a 1966 Toronado that has a vapor lock problem after it sits for 30 minutes. It appears that the float valve is getting hot and sticking shut.
Have any of you installed heat shields on your carbs to prevent vapor lock? What design works best? One protrudes wide from the base of the carb. The other is more or less the shape of the gasket. Any recommendations are appreciated.
This one: https://www.carbjunkys.com/Quadrajet...el-p/gss2f.htm
Or this one: https://www.ebay.com/itm/ROCHESTER-Q...-/253805259190
Old Jun 29, 2020 | 11:32 PM
shiftbyear's Avatar
Has the carb been rebuilt recently? I believe the original Toronado carbs had a needle seat issue. Also todays gas with ethanol may be a factor. I'd contact Everyday Performance or Cliff Ruggles and ask if the Toronado carbs require a heat shield or have hard hot starting issues. Viton tipped needles do not seem effected by ethanol fuel.
Old Jun 30, 2020 | 03:45 AM
bccan's Avatar
X2. If it hasn’t been rebuilt lately I would suggest going through it while installing new ethanol resistant needle & accel pump. It could also be sediment dragged up from the tank clogging the needle & seat if it has had recent attention. Theses cars had no big problems as a general rule.
Old Jun 30, 2020 | 05:27 AM
Yes, it was rebuilt by Daytona Parts and has their special valve.
Old Jun 30, 2020 | 07:52 PM
Ozzie's Avatar
It would seem like the wider one would be more effective. I don't know what part of the world you live in, but if you have mild winters you might consider limiting the heat riser.
Old Jun 30, 2020 | 08:27 PM
Thanks Ozzie.
If the shield doesn';t do the trick, the intake is coming off and the heat risers will be blocked. I live in Atlanta so there;s no need for a hot carburetor, even in the winter.
harascho
Mar 21, 2017 02:54 AM
cwb442
Apr 18, 2016 08:29 PM
71 Cutlass Ragtop
Apr 17, 2015 08:42 AM
Redog
Jul 23, 2012 11:56 PM
68ragtop
Sep 12, 2008 09:45 AM
