Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
425 cam bank angle ID
Old June 24th, 2015, 05:47 PM
lemoldsnut's Avatar
I am sure this has been discussed before maybe lots of times but did not find the info I was looking for. Sometimes the search mode is not that productive. Could be me.
I found this info. and those of you in the know might be able to help.
This is from 442.com
Is this true??
425 #D coded block (66-67 NON - Toro all were 45 degree and had .841" lifters)
425 #D coded block (66-67 Toro all were 39 degree and had .921" lifters
Maybe Joe P. or someone with similr knowledge can help.
I have a D block but not sure what it came out of.
Thanks in advance.
Larry
lemoldsnut is offline
Old June 25th, 2015, 06:05 AM
Run to Rund's Avatar
67 425s were supposedly 39 deg. even with the .842" lifters. I'd check with a dowel in adjoining lifter bores and see if the included angle is 90 deg. or less using a piece of paper as an indicator of 90 deg.
Run to Rund is offline
Old June 27th, 2015, 09:25 PM
lemoldsnut's Avatar
I have what I believe is a 66 block, came with B heads and toro intake as well as other parts that were all aftermarket. Lifters are same as 455 I had one I could compare to.
Not sure of cam bank angle.
Old June 27th, 2015, 10:08 PM
2blu442's Avatar
I know there's an old thread from several years ago with pictures and details on different ways to measure this. I don't remember who created the thread, but I believe several members added to it. If I can come up with it I'll post the link.
John
2blu442 is offline
Old June 27th, 2015, 10:45 PM
svnt442's Avatar
Something about a dimple I think?
svnt442 is offline
Old June 28th, 2015, 03:30 AM
Here you go:
And if you want even more information about it, see this thread.
MDchanic is offline
Old June 29th, 2015, 10:26 PM
64Rocket's Avatar
It is pretty easy, big lifter = 39* small lifter = 45*
I'm sure there are exceptions, but 99.9 % there it is.
Gene
64Rocket is offline
jhoppeolds
August 21st, 2014 05:26 PM
Octania
June 1st, 2014 12:21 PM
Old Olds Fan
October 2nd, 2013 05:19 AM
raymondh36965
March 24th, 2010 06:10 AM
nonhog
August 25th, 2009 03:59 PM
Quick Reply: 425 cam bank angle ID
