Looking for source for 425 45 degree bank angle camshaft
Old Aug 5, 2014 | 09:52 PM
jhoppeolds's Avatar
Currently doing a stock rebuild a '65 425 Starfire engine. Is there a source for a stock grind camshaft? If not, what is the overall availability of the early 45 degree cams?
Old Aug 5, 2014 | 11:18 PM
Smitty275's Avatar
Engine Builder
Readily available from most cam companies. I have one on the shelf for sale. Unfortunately I'm not going to be in the shop for several days.
Old Aug 6, 2014 | 04:32 AM
cutlassefi's Avatar
Or I offer custom grinds as well. Thanks.
Old Aug 6, 2014 | 11:27 AM
edzolz's Avatar
I have a new in box Erson TQ 20. 45 degree cam. $75 plus the ride.
Old Aug 6, 2014 | 01:17 PM
Run to Rund's Avatar
Comp Cams can grind them also.
Old Aug 12, 2014 | 04:34 AM
The Flash's Avatar
whats a good size cam for something above stock?
my engine is at the re builder and cam was worn
1966 425
thanks
Old Aug 12, 2014 | 06:09 AM
cutlassefi's Avatar
Erson MP2 would be perfect for a better that stock replacement.
Old Aug 12, 2014 | 07:26 AM
The Flash's Avatar
ill look in to that
thanks
Old Aug 12, 2014 | 08:12 AM
The Flash's Avatar
any ideas where i can find one of these cams?
PBM performance has it listed but there checkout is not working
before i pickup the phone i want to see if there are any other options
thanks
Old Aug 12, 2014 | 11:04 AM
cutlassefi's Avatar
Yes any Erson dealer can get you that cam.
Old Aug 12, 2014 | 04:02 PM
L69's Avatar
L69
Mark from cutlassefi. Knowledgeable and honest
Old Aug 14, 2014 | 06:20 AM
The Flash's Avatar
just to double check, this cam is very big compared to stock also the discription does not say its for a 45 degree 425 engine
Old Aug 21, 2014 | 10:32 AM
jhoppeolds's Avatar
I was looking at the Erson M/P1 as a suitable replacement for the stocker in my '65 Starfire 425, but the Erson catalog only shows 39 degree cams and numerous attempts to call them to see about any of their cams being ground in a 45 degree bank angle only resulted in a busy signal (even after hours). Seems like the phone is off the hook. Also called Comp Cams and was told they are currently not offering any cams in a 45 degree angle due to the lack of blanks.
Old Aug 21, 2014 | 10:57 AM
The Flash's Avatar
after measuring turns out i have a 45 degree engine have you heard anything about camcraftcams com?
Old Aug 21, 2014 | 11:21 AM
70cutty's Avatar
Beer Connoisseur
You guys should contact Mark - Cutlassefi for all your cam questions and needs. Great guy to deal with, he has helped many with their cams and more.
Old Aug 21, 2014 | 11:28 AM
The Flash's Avatar
i spoke to the guy at camcraft and he seamed knowledgeable about the Olds engine he even showed me how to check to verify it was a 45 degree engine.
On there web site it states that it should be verified as well as lifter diameter and that was new to me so that's why i was asking.
Old Aug 21, 2014 | 05:26 PM
cutlassefi's Avatar
Once in a blue moon you'll find an Olds block that'll have both oddities, i.e. a 45 degree bank angle AND a .921 lifter bore. So if it has a .842 lifter bore it most likely will be a 45 degree block and vice versa.
lemoldsnut
Tech Editor's Desk
Jun 29, 2015 10:26 PM
Octania
Jun 1, 2014 12:21 PM
Old Olds Fan
Oct 2, 2013 05:19 AM
raymondh36965
Mar 24, 2010 06:10 AM
nonhog
Aug 25, 2009 03:59 PM
