Shocks
Old Aug 26, 2013 | 08:08 AM
64F85Mark's Avatar
Sparky
Question Shocks
Hello
I need to change the shock absorbers on my 64 F85. The drivers rear seems to sag on occasion. Question is, should I just stick with the recommended stock shocks or has someone discovered a brand or type that work better than the original type for this car?
Sparky
Old Aug 26, 2013 | 08:51 AM
Originally Posted by 64F85Mark
Hello
Sparky
I'm not sure what you mean by "sag on occasion", but normal shocks have no affect on ride height. That would be controlled by the springs. As for shocks, Monroe Gas Shocks are good, reasonably priced shocks for a stock driver. KYBs are probably better if you want better handling (though keep in mind that the rest of the suspension needs to be in good shape also).
Old Aug 26, 2013 | 09:17 AM
64F85Mark's Avatar
Sparky
Maybe I have a sick spring. What I mean by sags on occasion is that sometimes when I get out and look at the back end the drivers side seems to be sitting a little lower, definatley not level. This is not always the case, most of the time it is level.
Thanks for you help.
Sparky
72Cutlass
Apr 16, 2008 07:48 AM
Pghstarsky
Jan 18, 2008 04:21 AM
mojorison
Jul 11, 2007 04:44 PM
aristellier
Dec 19, 2006 03:51 PM
J'ville
Aug 19, 2006 01:07 PM
