Hotchkis / Global West / Currie Rear LCA's, and installing coil springs w/ no weigh
Old Jan 2, 2011 | 04:20 PM
oldzy's Avatar
Anyone use the Hotchkis 1302 Rear LCA's? If so, how do you like them? Any bind noticeable? I have them, but considering getting something like GW's poly/joint (or poly/delrin) arms, or Currie Currectrac's poly/joint arms.
Also, what is the trick to installing coil springs with these aftermarket rear lower arms? Stock... I would just jack the car up, put on stands, let the rear end sag down, then pull out the coil springs... simple. Not so in this case. In the pic, the lower arms hit the axle bracket thingy which stops the rear end from going any lower.
At present, I have the coil springs in, one side completely bolted up upper and lower (not tightened though). I just can't line up the drivers side lower arm hole in the axle. I got the bolt through the hole on one side of the arm. It is shy like 1/4 inch from going completely through the other side of the arm. That is how close it is (see last pic below). Axle and arm do not want to seem to budge more though. I am assuming a coil spring compressor might do it? thx
DR_DAN
Mar 9, 2015 05:48 PM
oldzy
Suspension & Handling
Jun 19, 2011 07:56 PM
oldzy
Jun 7, 2011 12:11 PM
oldzy
Mar 2, 2011 08:40 AM
oldzy
Jan 18, 2011 03:44 PM
