1970 Cutlass S Suspension
Old Mar 27, 2021 | 10:19 AM
wherlehy's Avatar
OK Experts,
Can the rear springs be removed by lifting the car and letting the axle hang? Or do I need to compress them?
Old Mar 27, 2021 | 10:23 AM
oldsrock's Avatar
Disconnect the lower shock mounts and they’ll come out.
Old Mar 27, 2021 | 10:25 AM
wherlehy's Avatar
Thank you - will try!
Old Mar 27, 2021 | 10:26 AM
wherlehy's Avatar
Any recommendations on springs and shocks - I want to raise the car higher than stock.
Heavy duty station wagon coils?
Gas tube shocks?
Old Mar 27, 2021 | 01:23 PM
As the others said set the car frame on jack stands just in front of the rear wheels. Note the pigtail position of the springs as they do have to clocked. Place a floor jack under the pumpkin, remove the lower shock mounting, and lower the rear end. The springs will have no tension on them and pull right out. Moog cargo coils will raise your rear and you can still use the stock shocks. I like the KYB Gas Adjust.
Old Mar 27, 2021 | 04:42 PM
wherlehy's Avatar
Thank you - I will let you know how it turns out.
wherlehy
Suspension & Handling
Mar 15, 2021 05:14 PM
block727
Jun 10, 2020 08:17 PM
SeanMiller063
May 26, 2016 05:40 AM
bigjaythe1st
May 8, 2012 05:45 PM
pcard
May 14, 2011 02:54 PM
