1970 Cutlass S Suspension
As the others said set the car frame on jack stands just in front of the rear wheels. Note the pigtail position of the springs as they do have to clocked. Place a floor jack under the pumpkin, remove the lower shock mounting, and lower the rear end. The springs will have no tension on them and pull right out. Moog cargo coils will raise your rear and you can still use the stock shocks. I like the KYB Gas Adjust.
bigjaythe1st
Suspension & Handling
May 8, 2012 05:45 PM
