Video - 67 Cutlass Handling
Old August 6th, 2018, 01:03 PM
pmathews's Avatar
Talking Video - 67 Cutlass Handling
Video after doing suspension upgrades to a 1967 Oldsmobile Cutlass Supreme convertible. The car weighs 4,060 lbs full of gas, so very heavy, not including my 260 lb frame, but fun to drive after the mods ->
* 330 High Compression engine, so not a big block
* Stiffer 1 1/8" front sway bar (correction = 1 1/4")
* Hellwig adjustable rear sway bar
* stiffer coils springs and shocks
* tubular front and rear control arms
* tall ball joints.
If I emptied my trunk of tools and such, I would probably lose 50-75 lbs. I weighed using four point scales at the dyno shop, so it's accurate. Maybe I've got too much rust, bondo, and undercoating (haha).
Last edited by pmathews; August 10th, 2018 at 03:09 PM. Reason: corrected sway bar size
pmathews is offline
Old August 6th, 2018, 02:35 PM
therobski's Avatar
are you having fun or what?? Great running Old Olds!!
therobski is online now
Old August 10th, 2018, 05:30 AM
BlackDogJake's Avatar
Great video!
Do you mind sharing the parts you used here?
Are both sway bars and the control arms from Hellwig? Curious what springs/shocks you used also.
BlackDogJake is offline
Old August 10th, 2018, 03:07 PM
pmathews's Avatar
* Front springs are Moog 6041, with a 1/2 coil cut (was a little too high with the full spring)
* Rear springs are cargo coils (CC501), sits a little too low, so I installed a 1# spacer
* Front 1 1/4" sway bar is cheap aftermarket, probably Chinese, but works fine. It stays flat in the corners
* Rear sway bar is Hellwig 55864, a bit pricey at $280, but I didn't want to bolt the sway bar ends to the rear control arms. The Hellwig unit is independent.
* Front A-arms are tubular, bargain units off eBay, so they took some grinding and massaging with a hammer and torch to fit, but I only paid $100 for uppers and lowers, so it was worth the labor
* Rear tubular control arms are cheap eBay specials with adjustable uppers to help with pinion angle, and they work perfectly
* Shocks are KYB KG5507 and KYB KG4515, not bad, but I could have done better on these. They are a little too soft for my stiff springs.
pmathews is offline
Old August 10th, 2018, 06:12 PM
I don't think it's performing very well. I need to road test it myself to verify....
Great looking car BTW!!
Allan R is offline
Old August 5th, 2021, 05:30 AM
Update?
Paul - Curious how this setup is performing? Any changes/updates or regrets?
Old August 5th, 2021, 06:24 AM
pmathews's Avatar
Handles great, but sway bar issues
It's running great, my only problem is the larger sway bar is putting a lot of stress on the frame attachment points, and the bolts are pulling through. I had to tap and run a larger bolt on one that pulled through and wouldn't stay tight. I am looking at using 'nut-serts' as a solution.
pmathews is offline
frozencaveman
Suspension & Handling
October 10th, 2020 09:15 AM
Cutlasskyle
March 15th, 2018 09:54 AM
4424me
Drivetrain/Differentials
November 30th, 2012 08:16 AM
cuttysupreme72
September 22nd, 2012 04:31 AM
oldzy
January 3rd, 2011 02:38 PM
Quick Reply: Video - 67 Cutlass Handling
