coils & shocks 1972 cutlass s
Old Dec 27, 2017 | 04:12 AM
bronxdevine's Avatar
hello guys just picked up a 1972 cutlass it has air shocks in the rear that do not stay up when inflated with air after a couple of days & clamps on the front springs to drop it 2 inches would like to keep the 2 inch in the front would like to replace rear & front shocks & coils would like to keep the same stance any recommendation would be appreciated thank you
Old Dec 27, 2017 | 06:02 PM
csouth's Avatar
Is that inflated or after its settled, because it looks perfect.
Old Dec 27, 2017 | 06:08 PM
that's in flatted would like the same stance with the coils & shocks just don't know what to get ?
Old Dec 27, 2017 | 07:27 PM
csouth's Avatar
One thing about changing the shocks and coils is that you're probably dealing with old springs that are currently sagging and lowering springs are sold as inches compared to original height. What diameter wheel are you running now?
Old Dec 27, 2017 | 08:02 PM
running 20 inch rims
Old Dec 27, 2017 | 08:15 PM
csouth's Avatar
For inexpensive solution, I would probably get the 2" drop springs from CPP I think they are $95 a pair front and rear. I would spend the money getting some decent shocks though, probably the Bilstein monotube front and rear set, I've seen them for like $350 on Amazon.
One thing is if the spring is a little low, you can always shim it. If its too tall, you're stuck. You'll find cheaper shocks out there, but with NY streets you need something that will last.
rothlane'68
Jan 25, 2016 06:47 AM
red&blue442
May 29, 2011 11:48 PM
442_Mustang
Suspension & Handling
Apr 14, 2010 02:21 PM
Wilson05
May 12, 2009 10:04 AM
